Smallest Ambarella Car DVR a.k.a. Mini 0801
Discussion in 'Mini 0801' started by sudo, Apr 7, 2013.
  1. Lunar
    Lunar Active Member
    377
    116
    Herefordshire
    Country:
    United Kingdom United Kingdom
    Dash Cam:
    3x Mini 0801 / Mio-368WDR+AGF
    I suspected the bitrate had been reduced slightly, as I noticed it was lower than previously when I checked one video file taken inside the home, but put it down to the fact it records at a variable bitrate, so sometimes it writes at a lower figure, and other times when there's lots happening it will record at a higher rate.
    The brief comparison tests I did this morning indicated no noticeable deteriation, though I'll do some checks, but in view of your observations, I would not be at all surprised to find they have reduced the recording bitrate in order to bring some stability back to the camera, because previously out on the road my 0913 firmware was recording at about 17200kbsp, which is quite high, and is much higher than my Mio 368 for example which writes at about 13500kbps. In fact there are not many dashcams out there that write at such a high bitrate as the mini 0801.
    So it would make sense to reduce the bitrate slightly simple because many of these camera could not sustain it without have lots of issues. Personally I would rather have a much more reliable camera with a lower bitrate than one with a very high bitrate that was volatile and unreliable. Even joklin stated many times that he considered the mini 0801 camera high recording bitrate as possibly a prime cause of many issues some people have been experiencing.
    Also when you consider that users have stated that disabling the audio seemed to offer a fix for some, plus other patterns too is very indicative that it simply struggled to maintain and write at that higher bitrate, on some cameras anyway.
    If it means the image quality is reduced a touch, in order to get a full stable working camera then I think most people would consider that a better option than one that gives a better image but only when it rarely works...lol You can't have it both ways guys...lol. Though in reality I've not seen a significant difference in image quality, but if indeed it is writing at a reduced bitrate which my money is on, then yes it's posible the image will likely not be quite as good.
    What do you want ? great image quality and crap reliability, or a not quite so good image, and a fully working stable camera. ? I think the choice is obvious. and you do have to look at the pluses.. we do get a longer recording time...lol. and the real big plus.. you still own one of the most discreet cameras you can buy.... but now it works... we hope. :)
    After all it is only a car dash camera, and not something like a 3ccd camcorder costing several hundred pounds or a BBC broadcasting studio camera. ;-)
    Tobi@s, jokiin and Peter Wilson like this.
  2. JazJon
    JazJon Well-Known Member Retailer
    1,524
    418
    San Francisco, California
    Country:
    United States United States
    Dash Cam:
    http://RoadCam.com
    My new E-PRANCE 0801 (GPS with no-internal-8gb) is on the way soon. I'm hopping it arrives with October firmware as well. (re-cap, I returned it to fix dead/stuck pixals that showed up on low light recordings) E-PRANCE is sending me another Samsung 32GB Class 6 card as well. They even pre-tested both over night for me.
    2013-11-10 19:25:00SYYX Despatch from Sorting Center
    2013-11-11 00:30:45SHENZHEN Arrival at Sorting Center
    2013-11-11 11:46:11SHENZHEN Despatch from Sorting Center
    My Givoe/Aliexpress (GPS with internal-8gb) is still running rock solid on firmware 20130924. It never trips up, and records day after day without fail. The only problem is the G-Sensor no longer will calibrate. (and I assume not working period) I don't care about G-Sensor right now though.
    [​IMG]
    So since I have a new 0801 on the way, and my 0801 is currently my REAR dashcam, I'm going to go ahead and try using 20131026 just to give us more feedback. I know if it ain't broke don't fix it usually applies, but I want to continue pushing progress here :) I can always downgrade to 0924 again.
    20131026 https://drive.google.com/file/d/0BzaK5CGt2pO6cnJJT1FXankzMzA/edit?usp=sharing (Thanks Lunar)
    Stand by for my results. (hopefully it's just as stable and possibly restores G-Sensor but doubt both)
  3. Arthur
    Arthur New Member
    3
    1
    Country:
    South Africa South Africa
    Dash Cam:
    Mini 0801 (purchased 7 Nov 2013)
    I'm new to dashcams and this forum (my first post).
    Last week bought two of these (GPS version) via AliExpress/Xinrantechnologies.
    Ordered on Thursday 7 Nov and they arrived by courier in South Africa on the 13th - impressively rapid service.
    They came with the 20131026 firmware.
  4. JazJon
    1,524
    418
    Country:
    Dash Cam:
    http://RoadCam.com
    Welcome to the club, I hope they prove to be stable with the 20131026 firmware. (so far so good, keep us updated once the cards are full and in recycle/loop mode)
  5. Peter Wilson
    Peter Wilson Active Member
    426
    62
    Newcastle upon Tyne
    Country:
    Dash Cam:
    Mini 0801 DashCam and Blackvue DR550GW, iPhone 4S.
    Well mines been on all night and is still videoing. I am going to check out how much space is on the card it should be near full by now.
  6. Vapourman
    Vapourman New Member
    8
    12
    Country:
    Update on my GPS/no int. memory/firmware 20131026 version….
    Now been in and running for a week. No problems whatsoever! All clips recorded to and from work each day etc. Plays back fine on Registrator program with all data. Seems stable enough so far.
    I ended up doing as Lunar said and slightly bent the mini usb power plug to get a better connection. However, am about to go out and install a new connector with a 90 degree plug (to make it look a little tidier!). I also changed the grey 3M sticky pad for a black one. Both "aesthetic modifications" courtesy of ebay!
    Will try and post sone photos of it installed later on.
    Other than that, slightly disappointed with "complete darkness/headlights only" night quality. Not really sure what I expected though. Fine with street lights, excellent in daylight. May try a few different AE bias settings and see what happens. It's been on +0.7 all week. Audio quality is more than acceptable when played back on pc.
    Shame it wouldn't fit directly behind my rear view mirror, but my windscreen is quite "flat" or should I say with very little rake and the mirror sits on a short stalk very close to the screen. Have had to mount it alongside the mirror which means the little blue led is slightly distracting at night. I feel a small piece of sticky tape might be in order.
    Overall, well pleased with this value for money device :)
    Lunar, JazJon and jokiin like this.
  7. liam0918
    liam0918 Member
    36
    1
    birmingham
    Country:
    what memory card you using?
  8. Peter Wilson
    426
    62
    Newcastle upon Tyne
    Country:
    Dash Cam:
    There is also ISO settings but it only goes upto 400ISO
    Mine has been supplied with 32Gb Class 10 samsung card. I have managed to make the camera crash I have locked all the files by pressing the menu button and stuff and it only has 520mb of storage left. DOH
    It came up with card too slow then io card error.
  9. Vapourman
    8
    12
    Country:
    I'm using a 32Gb Samsung. I think it's class 6 but the writing on it is soooo small? It was supplied with the camera from e-prance via Amazon.
  10. Vapourman
    8
    12
    Country:
    I may well have a play around with the ISO settings as well and see what difference that makes in the dark.
    Not sure what has happened with your total lock up. May be worth trying the "master reset" by holding in the on/off button on the side for a ten seconds or so?
  11. Peter Wilson
    426
    62
    Newcastle upon Tyne
    Country:
    Dash Cam:
    I filled the card up and then ended up in the playback menu and accidentally clicked lock all video instead of lock one. so it wont record over any files and its out of room to record anything else. LOL my bad.
  12. Buzzy
    Buzzy New Member
    16
    2
    Country:
    My update as suggested I downloaded the Registrator Player software for my 0801 carcam run the .exe file program opened o/k open folder containing .mov clips inputed o/k but when run comes up with Codec not found avci & AAC it then suggest to instal k-lite . Went back to Registrator site and tried to download there highlighted link at top of page after hunting through menu I downloaded there missing codec all I got was a Trojan virus picked up by Microsoft essentials called Win32/wysot.c then did a malwarebyts scan that picked up 12 maleware program's something .pup files. So Iam now not sure which program caused this havoc . Could any body advise where to get the codec without all these problems. Sorry if I have put this request into the wrong post if I have please advise which posting to visit. Thanks buzzy
  13. JazJon
    1,524
    418
    Country:
    Dash Cam:
    http://RoadCam.com
    I've used shark007 for years.
    http://shark007.net
    Do a custom install decline usual bundled junk.
  14. Lunar
    Lunar Active Member
    377
    116
    Herefordshire
    Country:
    Dash Cam:
    From todays clips out in the car, it would appear the bitrate on this latest Eprance 1026 GPS ONLY firmware, as been dropped from around the 17000kbps mark down to aprox 14000kbps.
    some of the 1 min clips were at anything from 13100kbps and the highest I noticed was 14200kbps.
    Comparing actual image quality side by side with previous clips shows very little drop in quality, not to my eyes anyway, though there obviously has to be a slight drop, it's just not that noticeable...and certainly not enough to make me want to rush back to 0913, even though mine worked fine on 0913.
    So I think overall, in theory this latest 1026 (Eprance GPS Only) firmware should ease speed related write issues on some camera's. where either the camera hardware itself or the card or both are not optimum. AIS previously..best to have a camera that works! than one with superb image quality that doesn't work.
    Incidently.. just a bit of useless info I noticed today.
    The file sizes for exactly 1 minute clips taken of the exact same scene using this Eprance 1026 firmware, are identical to the files sizes produced by the Eprance 0922 firmware on their GPS+8GB camera's, and by identical I mean exactly the same size down to a single byte. Meaning that both those versions of firmware obviously use exactly the same bitrate algorithm.
  15. Buzzy
    Buzzy New Member
    16
    2
    Country:
    Not sure what you do with this link Jaz-Jon, do you just download the file and run it have you got to do anything else thanks buzzy
  16. Lunar
    Lunar Active Member
    377
    116
    Herefordshire
    Country:
    Dash Cam:
    I found I could play the files from the mini 0801 okay with Registrator and other viewers on my Win7 but it came back with a similar msg about needing another codec when playing video's from my Mio 368 camera, which I thought was rather strange as both output in .MOV format and you would think if it plays .mov files from one camera, it should also play the .MOV files from the other camera..lol very weird. There obviously must be differences in the algorithm compression engine they are using. Hence why it works with one codec and not another.
    Anyway Buzzy.. I installed K-Lite basic codecs a few weeks ago and all was well, it's not very big anyway. I've just uploaded it onto my google-drive for you if you want it. I have scanned it again with the lastest Kaspersky virus scanner and its fine. HTH
    K-LITE BASIC CODECS. https://drive.google.com/file/d/0BzaK5CGt2pO6RDdNSFpxUm0zTXc/edit?usp=sharing
    and this is the latest Registrator Video/GPS Playback viewer if anyone wants it.
    REGISTRATOR.EXE https://drive.google.com/file/d/0BzaK5CGt2pO6czNFMzZFNFNuYTA/edit?usp=sharing
    OldGoat and jokiin like this.
  17. Buzzy
    Buzzy New Member
    16
    2
    Country:
    Hi luner not my day today tried to download from your link and was blocked by gmail not sure why ? The gmail account is not my main mail . But it said about asking permission from you I do have a gmail account but I use the hotmail account on this site not sure how to continue. Thanks buzzy
  18. Lunar
    Lunar Active Member
    377
    116
    Herefordshire
    Country:
    Dash Cam:
    No problem matey.. totally my fault...ooops.. All sorted! .. it should download now... it defaults to allowing access to just me, and I forgot to set it to share with anyone who has the link. sorry about that Buzzy.... (Lunar hangs his head in shame..lol)
  19. Klippie
    Klippie New Member
    17
    5
    Country:
    Lads,
    I've decided to buy one of these camera's as my new dashcam, as there are lots for sale can someone please recommend me a trustworthy seller regarding quality of the camera and the most recent stable firmware.
    Thanks in advance...:)
  20. Buzzy
    Buzzy New Member
    16
    2
    Country:
    Thanks again lunar have now downloaded both of your files will try instal later on . As Iam now trying to access my gmail account after it requested me to change my password I seem to have made a complete mess of it what a good Iam having. Buzzy
Share This Page
